Budman's on going joke fest
Oldie but still good.
COMMON TOOLS AND THEIR USES
SKIL SAW :
A portable cutting tool used to make boards too short.
BELT SANDER :
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
WIRE WHEEL :
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****' . Will easily wind a tee shirt off your back.
DRILL PRESS :
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
Channel Locks :
Used to partially round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW :
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS :
Generally used after Channel Locks to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH :
Used almost entirely for igniting various flammable objects in your shop and creating a fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW :
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. Very effective for digit removal!
HYDRAULIC FLOOR JACK :
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW :
A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash after you cut on the inside of the line instead of the outside edge. Also (as with the Table Saw) excels at amputations.
TWO-TON ENGINE HOIST :
A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER :
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER :
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR :
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER :
A tool used to make plastic pipe too short.
HAMMER :
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object you are trying to hit. Also very effective at delayed fingernail removal.
UTILITY KNIFE :
Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. These can also be used to initiate a trip to the emergency room so a doctor can stich up the damage.
SON OF A BITCH TOOL :
Any handy tool that you grab and throw across the garage while yelling 'Son of a bitch' at the top of your lungs. It is also, most often, the next tool that you will need.
Safety Glasses: A protective device to protect the hairline while using power tools.
Air Compressor: Noise generation machine used to drive the wife out of the garage.
Disposable Latex Gloves: Used to eliminate the need to wash ones hands before going to the restroom.
Digital Vernier Caliper: Expensive reminder to purchase watch batteries. Again.
WD-40: Shop toilet air deodorizer.
Repair Shop Radio: Device used to start political arguments.
Nine Important Facts To Remember As We Grow Older
#9 Death is the number 1 killer in the world.
#8 Life is sexually transmitted.
#7 Good health is merely the slowest possible rate at which one can die.
#6 Men have 2 motivations: hunger and hanky panky, and they can't tell them apart.
If you see a gleam in his eyes, make him a sandwich.
#5 Give a person a fish and you feed them for a day. Teach a person to use
the Internet and they won't bother you for weeks, months, maybe years.
#4 Health nuts are going to feel stupid someday, lying in the hospital, dying of nothing.
#3 All of us could take a lesson from the weather. It pays no attention to criticism.
#2 In the 60's, people took acid to make the world weird.
Now the world is weird, and people take Prozac to make it normal.
#1 Life is like a jar of jalapeno peppers.
What you do today may be a burning issue tomorrow.
Two TV antennas got married.
The wedding was crap,
but the reception was excellent.
VIRGIN TEST
Paddy was planning to get married and asked his doctor how he could tell if his bride is a virgin.
The doctor said, “Well, you need three things from a do it yourself shop. A can of red paint, a can of blue paint… and a shovel.”
Paddy asked, “And what do I do with these, doc?”
The doctor replied, “Before the wedding night, you paint one of your testicles red and the other one blue. If she says, ‘That’s the strangest pair of balls I ever saw.’, you hit her with the shovel.”
Two of Trump's wives are immigrants. Just goes to show that those people are willing to do the jobs Americans aren't willing to do.
Errr. . . .those would be 'ex-wives'. Apparently the compensation earned did not cover the requirements of the job.
1) Marry Rich American
2) Put up with verbal diarrhea for a few years.
3) Not explaining this part.
4) Profit!
Okay, okay. I know. I'm toeing the Political line. Happy to delete if the voices in my head get too loud.
A man has a 25-inch penis...
...and he thinks it is way too big, so he looks for ways to make it smaller. One day, he finds out about a witch in the woods who can solve his problem.
He goes to see the witch and she tells him to look for a frog by the stream and ask the frog to have sex with him. The frog will say no, and his penis will shrink by five inches. So he finds the frog, and asks him, "will you have sex with me?" The frog says "no!" and the guy's penis shrinks by five inches.
He thinks this is great and asks again, "will you have sex with me?" The frog again says "no!" and his penis shrinks again by five inches.
The man is very pleased. He still has a 15-inch penis. Thinking that it's still too big and a ten-inch dong is plenty to satisfy the ladies, he decides to ask the frog one last time, "will you have sex with me?"
"How many times do I have to tell you? No! No! No!"
A man walks into a bar and orders 8 shots of vodka.
"Rough day?", says the bartender as he starts pouring the shots.
The man downs each shot as soon as it's full, then says "You wouldn't believe it. You'd be drinking like this too if you had what I have."
"What's that?"
"25 cents."
What's the difference between a Brown Noser and a Shit Head?
Depth perception.
How do you know when you're on the ladder of success?
You look up and see nothing but Assholes.
You look down and see nothing but shitheads.
Only to become dismayed when you realize that you have reached your highest point of competence and there you shall remain.
House phone rings, gotta be a telemarketer. I get excited.
Me. Hello.
Comcast. Good evening Mr Kent, have you considered getting with the world's number one selling broadband?
Me. The Spice Girls? All the time.
Comcast. (dead air.... 1..2..3..4...click)
Not even a courtesy chuckle
GOT MY CONCEALED GUN PERMIT YESTERDAY ......
...and went over to the local Bass Pro Shop to get a small 9mm for home protection. When I was ready to pay for the gun and bullets, the cashier said "Strip down, facing me."
Making a mental note to complain to the NRA about the gun control wackos running amok, I did just as she had instructed. When the hysterical shrieking and alarms finally subsided, I found out she was referring to how I should place my credit card in the card reader!!!
I've been asked to shop elsewhere in the future.
Memorable password
I have to make sure you understand that you always choose a memorable password!
My wife helped me install a new computer.
Once it was completed, she told me to select a password,
Selecting a word that I will always remember. She was kind of short with me so I got an attitude. :mad
When the computer asks me to enter it, I looked at my wife
And with a macho gesture and a wink in my eye, I selected a password:
“Mypenis”
When I "enter", to validate the selection, my wife Collapsed with laughter and rolled on the floor in hysteria!!
:wtf ( I was not paying attention).
The computer had replied:
TOO SHORT- ACCESS DENIED!
:facepalm
:p
Ole' Blue
A young Arkie goes off to college. Half way through the semester, having foolishly squandered all of his money on his girlfriend, he calls home.
"Dad," he says, "You won't believe what modern education is developing! They actually have a program here at Hendrix that will teach our dog, Ole' Blue how to talk!"
"That's amazing," his Dad says. "How do I get Ole' Blue in that program?"
"Just send him over here with $1,000" the young Arkie says "and I'll get him in the course."
So, his Father sends the dog and $1,000.
About two-thirds of the way through the semester, the money again runs out.
The boy calls home.
"So how's Ole' Blue doing son?" his Father asks.
"Awesome, Dad, he's talking up a storm," he says, "but you just won't believe this -- they've had such good results they have started to teach the animals how to read!"
"Read!?" says his Father, "No kidding! How do we get Blue in that program?"
"Just send $2,500, I'll get him in the class."
The money promptly arrives. The Arkie and his girlfriend are able to buy enough marijuanato last the whole semester. But our hero has a problem. At the end of the year, his Father will find out the dog can neither talk, nor read. Even though he was always pretty much able to lie his way out of trouble, the Arkie asked his girlfriend to help him think of a really good lie to tell his Dad. She very quickly came up with a plan for him.
So she has him shoot the dog.
When he arrives home at the end of the year, his Father is all excited.
"Where's Ole' Blue? I just can't wait to see him read something and talk!"
"Dad," the boy says, "I have some grim news. Yesterday morning, just before we left to
drive home, Ole' Blue was in the living room, kicked back in the recliner, reading the Wall Street Journal, like he usually does".
"Then Ole' Blue turned to me and asked, so, is your Daddy still messing around with that little redhead who lives down the street?"
The Father went white and exclaimed, "I hope you shot that lying damn dog before he talks to your Mother!"
"I sure did, Dad!"
"That's my boy!"
The after story:
The kid married his girlfriend, they both went on to law school in Fayetteville ,
he became Governor of Arkansas and President of the United States and you
already know what a lying bitch his girlfriend turned out to be.
:laughing
Life goes on and so does politics.
Trump is next.
While walking down the street one day, a Republican head of state is tragically hit by a truck and dies. His soul arrives in heaven and is met by St. Peter at the entrance.
"Welcome to Heaven," says St. Peter. "Before you settle in, it seems there is a problem. We seldom see a high official around these parts, you see, so we're not sure what to do with you."
"No problem, just let me in." says the Republican.
"Well, I'd like to but I have orders from higher up. What we'll do is have you spend one day in Hell and one in Heaven. Then you can choose where to spend eternity."
"Really, I've made up my mind. I want to be in Heaven," says the Republican head of state.
"I'm sorry but we have our rules." And with that, St. Peter escorts the Republican to the elevator and he goes down, down, down to Hell. The doors open and he finds himself in the middle of a green golf course. In the distance is a club and standing in front of it are all his friends and other politicians who had worked with him, everyone is very happy and in evening dress. They run to greet him, hug him, and reminisce about the good times they had while getting rich at expense of the people. They play a friendly game of golf and then dine on lobster and caviar. Also present is the Devil (a Republican, too), who really is a very friendly guy who has a good time dancing and telling jokes.
They are having such a good time that, before he realizes it, it is time to go. Everyone gives him a big hug and waves while the elevator rises. The elevator goes up, up, up and the door reopens on Heaven where St. Peter is waiting for him.
"Now it's time to visit Heaven." So 24 hours pass with the Republican head of state joining a group of contented souls moving from cloud to cloud, playing the harp and singing. They have a good time and, before he realizes it, the 24 hours have gone by and St. Peter returns.
"Well then, you've spent a day in Hell and another in Heaven. Now choose your eternity."
He reflects for a minute, then the head of state answers: "Well, I would never have thought it, I mean Heaven has been delightful, but I think I would be better off in Hell."
So Saint Peter escorts him to the elevator and he goes down, down, down to Hell. Now the doors of the elevator open and he is in the middle of a barren land covered with waste and garbage. He sees all his friends, dressed in rags, picking up the trash and putting it in black bags. The Devil comes over to the Republican and lays an arm on his neck.
"I don't understand," stammers the Republican head of state. Yesterday I was here and there was a golf course and club and we ate lobster and caviar and danced and had a great time. Now all there is a wasteland full of garbage and my friends look miserable.
The Devil looks at him, smiles and says, "Yesterday we were campaigning. Today you voted for us!"
