As I mentioned yesterday I signed up for the Truckee gravel race, mid-distance. Robert or Mike do either of you have any training tips? This is a new distance for me. I was thinking to keep up my interval training on Zwift once or twice a week and a long ride on the weekends (30+ miles) and then a short lunchtime ride (15 miles) at a fairly high intensity. My one run per week and keep up with lifting weights. Anything else you recommend?
Yes, yes I do
Good training needs two main things IMO - purpose and progressive overload.
Purpose is where you decide what specific aspects of your riding you want to improve. The list isn't that long for gravel racing - threshold, sprint power, endurance, durability, VO2 Max. They all affect each other, but you will see much better/faster results if you plan to work on a specific area for a few weeks. IME, the most important ones for a gravel race are endurance, durability, and VO2 Max in that order. It's literally what my coach had me work on first and the differences were amazing.
Progressive overload is how you actually make gains. This one is simple. Make every week harder than the last. Then take a week break and start again. Not doing this will lead to slow results at best and plateaus at worst. Do not do the same workout over and over again. Generally, rides that fit your specific purpose should be made harder over ones that dont. For ex, while training VO2 Max make those harder and leave the other riding the same.
So let's put those two together.
Endurance training is just saddle time. Overload it by increasing your hours on the bike weekly. Add hours to your longest ride - 2-3hrs, 3-4hrs, 4-5hrs. Work up to consecutive days if possible. If you can do 4-5hrs followed by 2-3hrs, you can do a 66mi gravel race no problem. Work on your fueling!!!!! These rides should be ridden at RPE 2-4, 4 being the pace where you just start to struggle to hold a conversation. You could do an interval day during a long endurance week. Just make sure it doesn't detract from your endurance hours.
Durability training is how you make it over that 8mile climb and still have something left for the remaining miles. These rides are generally "make yourself tired, then keep riding" or "ride a bunch, then do intervals". For ex, 2x20min tempo (or sweetspot if you are feeling spicy) intervals, then ride more at RPE 3. Progressive overload by increasing the intervals - 3x20, 4x20, 3x30 - and by increasing the extra riding. The extra riding can range from zero (straight into cooldown) all the way up to 3hrs. Doing this outside also trains technique, like putting out power over varying terrain and shifting and all that. Indoor tempo intervals on Tues and a durability ride on Sat would be productive (plus more endurance riding on other days). Also, you will need to fuel the f* out of these rides. Hopefully you practiced fueling during endurance rides.
VO2 Max work gives you punch and makes all those little rollers and rises so much easier. My coach's article has all the info you could need for this. Focus on the "real targets", especially unmistakable heavy breathing. Zwift probably has some great workouts for this. 4x4, 30/30s, 40/20s, etc. 2 of these a week with some endurance riding is more than enough. Just make sure to pick a harder VO2 workout each week. Also as described in the article, don't worry about Zwift's power targets. Just go all-out as necessary.
A practical guide for coaches to get more VO₂ adaptation from the same (or less) suffering. Build VO₂max sessions around oxygen kinetics to maximize time near VO₂max for more adaptation and less fatigue.
www.trainingpeaks.com
You have 14wks until race day. That's time for 4wks of endurance, a light week, 3wks of durability, a light week, 3wks of VO2 Max, and a taper. I'd do it in that order. Endurance first makes the durability easier and more productive, and they need time to "soak in". VO2 Max work can be done late and still feel the gains.
I'd limit gym work to once a week and make sure to avoid soreness. No need to overload it, just maintain. And I'd drop the running entirely - it will detract from your riding. A 60min VO2 Max interval workout will benefit you far more than a 45min run. Maybe you could run during the endurance portion, but def drop it during durability and VO2Max.
