Hello,
No sure if anyone seen that problem, but worth to ask.
So, on last trackday my rear brake (on s1000rr 2017, with ABS) seized completely, to release the wheel had to bleed brake fluid to release pressure. Since then I was trying to figure out what caused it and how to fix it, to make things more interesting - that problem happens only I ride the bike, when bike is not running there is normal amount of drag and travel for rear brake pedal.
Here is what I've done so far:
* bleed brakes + ABS (used moto-scan app to enable ABS bleeding procedure)
* triggered ABS pump and abs solenoids through moto-scan app - all seems to be working just fine, no "unnatural" sound.
* no errors reported in ABS module
After all those actions - problem still persist, after 5 minute ride on parking lot rear brake starts to lock up (was using RACE mode when did the testing)
Did one more thing - unplugged ABS/DTC module completely, which obviously disable any information on dash, like speed, DTC and lean angle information, except gear indicator. Did a test ride - no problem.
At this point - I'm thinking problem is in ABS/DTC module, and it causes bike to constantly "apply" rear brake electronically. I see few options:
* replace ABS module (with used one) - which most likely going to be PITA, since ECU might have to be updated to use new module
* get ABS delete parts from alpha racing and get rid of ABS completely.
* or the problem is in DTC actually, maybe, it "thinks" bikes is about to wheelie and applies rear brake to settle it down (not sure exactly how DTC handles this things).
So, my question - has anyone seen/experienced similar problem? am I missing something that I should have checked?
Thank you
Thank you
